#1634970 - 07/11/07 04:55 PM D16Z6 Ticking, sounds like a spun bearing, but...
SPAZ Offline
Loc: Mars
My engine is ticking pretty badly, sounds like a used sewing machine, however it idles fine minus the tick, so I'm pretty sure it's not a valve, I think it may be a spun rod bearing, but there is no metal in the oil? How do I diagnose this issue without pulling off the oil pan? I have no garage to work in at the moment. \:\(
avatar too big
#1635365 - 07/11/07 06:32 PM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: SPAZ]
Alloyking Offline
Loc: Minneapolis
-Does the ticking sound increase with Engine speed?
A spun bearing I believe will get louder with RPM
It could be that your timing belt or camshaft timing is off. But if the engine isn't running really bad, or backfiring.. I'd say it's a valve.
Sometimes you can also get a tick from bad bearings in an alternator, water pump, etc. I would imagine the sound from these would not get louder with the RPM.
If you can't remove the oil pan. I'd say get a long screw driver, then while the engine is running. Place the Screw driver end on various places and stick your ear against the handle. This will amplify the sound for you... and you might get a better idea on where the sound is comming from.
#1637742 - 07/12/07 11:10 AM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: SPAZ]
Import Tuner Offline
Gold Member
Loc: Tacoma, Wash..
You can pull the plug wires (one at a time) and see IF the noise deminishes once you've taken away the power stroke of the piston / rod / crankshaft assy...
Donny
Import Specialty Automotive
#1638998 - 07/12/07 03:53 PM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: Import Tuner]
SPAZ Offline
Loc: Mars
Awesome, that's what I'll do.
Also, if it is the bearing, am I going to have to get the rank resurfaced? I hasn't run very long with the ticking sound going on, can I just replace the bearing?
Edited by SPAZ (07/12/07 03:57 PM)
avatar too big
#1640607 - 07/12/07 11:43 PM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: SPAZ]
Gold Member
Loc: Tacoma, Wash..
Unfortunatly, rod knocks (read bearing failures) are generally caused by lack of lubrication or the motor being overreved...
Lack of lubriction would more than likely require the crank being turned...
Overreving would require the rod journal being resized...
It's not to often that you can just replace the bearing...
Donny
#1644277 - 07/13/07 09:38 PM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: Import Tuner]
SPAZ Offline
Loc: Mars
Yeah, this problem resulted from my oilpan having a ding in it that leaked a good majority of the oil out of the system, when I finally got the oil light, it was too late. \:\(
avatar too big
#1646666 - 07/15/07 02:16 AM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: SPAZ]
4doorEG Offline
Loc: Overland Park, KS
The single cam is cheap enough, it may be cheaper for you to find a used engine than it would be to PROPERLY fix your damaged engine.
#1653435 - 07/17/07 08:30 AM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: 4doorEG]
EBP_99 Offline
Loc: Ky
my 99 si also has a tickin sound but it doesnt get any louder or softer but does increase in speed as the rpms rise. ive been told that it could be either lifers pecking or valve chatter. is there any way to get a better idea which other than pulling the valve cover
ebp em1, dc 4-2-1 ceramic header, comptech intake, mugen twinloop, hr springs
#1653647 - 07/17/07 09:48 AM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: EBP_99]
Gold Member
Loc: Tacoma, Wash..
If you pull the valve cover, you'll notice you don't have lifters (I assume that's what you meant), so that may help to narrow it down for you...
Donny
#1656103 - 07/17/07 07:40 PM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: Import Tuner]
EBP_99 Offline
Loc: Ky
yeah i meant lifters, thats just what i was told by a mechanic who looked it up in his manual and told me thats what it was and that they had screw adjustments which meant that he could attempt to stop the noise if that was the cause instead of takin it to a honda dealer.
i dont know much about motors so i would not know either way.
any ideas on what it could be?
Edited by EBP_99 (07/17/07 07:41 PM)
#1656809 - 07/17/07 11:50 PM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: EBP_99]
Gold Member
Loc: Tacoma, Wash..
They are actually "cam followers" which simply follow the cam lobes and open the valve accordingly...
They are in fact adjustable and your mechanic should be able to perform that feat fairly easily...
Donny
#1657578 - 07/18/07 09:51 AM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: Import Tuner]
EBP_99 Offline
Loc: Ky
in that case does a price of $250 sound to expensive? its was a small shop in central Ky. another shop said $50-$60. quite a difference in my opinion
#1657610 - 07/18/07 09:59 AM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: EBP_99]
Gold Member
Loc: Tacoma, Wash..
I charge $60.00, so yea I'd think $250.00 is quite excessive...
Donny
#9109813 - 08/18/17 08:41 PM Re: D16Z6 Ticking, sounds like a spun bearing, but... [Re: ]
HYst Offline
I Kobe Shoes Nike figured the thing to do was push in Official Toms Shoes Outlet towards the tennis courts. Wethreaded our way Jordan Sneakers For Sale through the crowd, and to stay together we Cheap Michael Kors Handbags took eachother's hands. Nike Factory Store Only staying Nike Free Run 5.0 Womens together didn't require us to intertwine fin-gers. Yeezy Men That was strictly for pleasure. Air Max Sneakers It was very pleasurable.
The bands were all inside the tennis Hyperdunk 2014 courts, with their guitars and mix-ers and Discount Christian Louboutin Shoes keyboards and even a drum kit. Later, Zapatillas Air Max on Coach Bags On Sale Xnet, I found zapatillas nike baratas a Nike Soccer Cleats Boots Flickrstream of them smuggling all this stuff in, piece by piece, in gym bagsand under their coats. pandora outlet store Along Hogan Outlet with it Moncler Jackets Discount Marketplace all were huge Air Nike speakers, the kind yousee in automotive Air Jordan Retro Sale supply places, and among new jordan releases them, a stack Louboutin Wedding Shoes of… Nike Air Max Sale car bat-teries. I laughed. Genius! That was Nike Roshe Run how they were going to power theirstacks. From where I stood, I could see that Canada Goose Outlet they Jordan Shoes For Cheap were Michael Kors cells from a hybridcar, a Prius. Someone Uggs For Cheap had gutted an eco-mobile to power TOMS SHOES OUTLET the Cheap True Religion Jeans night's en-tertainment. The batteries continued outside the courts, nike shoes stacked upagainst the fence, tethered to the main stack by Yeezy Shoes Discount Marketplace wires threaded throughthe chain-link. I Ray Ban Sunglasses Online counted — 200 batteries! Christ! Those Nike Shox Cheap things weighed aton, too.
There's Adidas Originals Superstar no way they organized this without email and chaussure adidas pas cher wikis and mail-ing lists. And there's no cheap uggs for women way people this smart new pandora charms would have done that onthe public Nike Outlet Internet. This had all taken place on louboutin heels the Xnet, I'd bet my bootson it.
We just kind Nike Shoes Discount Marketplace of bounced around in the crowd for 23 IS BACK Store a while as the bandstuned up and conferred with one another. I Adidas Originals Stan Smith saw Trudy Doo from a dis-tance, in the tennis scarpe nike courts. She looked like she was in converse store a cage, like a prowrestler. Cheap Michael Kors Tote Bag She was wearing a torn Cheap Air Max Trainers wife-beater and ADIDAS NMD SALE ON LINE her hair Pandora Store Sale was in long,fluorescent pink dreads down Adidas Superstar Sale Online to her waist. She was Official NHL Jerseys wearing reebok running shoes army cam-ouflage pants and giant gothy boots with Negozi Pandora steel over-toes. As I watched,she picked up a heavy motorcycle Nike Shoes Sale Store jacket, worn as a catcher's mitt, andput it ジョーダン スニーカー on like armor. It probably was armor, ugg clearance I realized.
I tried to wave to her, to impress Ange I Air max dam guess, Vans Black Sneakers but she didn't retro jordans for cheap see meand I kind Nike Roshe Run Sale of looked like a spazz so I prada outlet stopped. toms sale The energy in Abercrombie and fitch store the Air Max Femme crowdwas amazing. You hear people talk about "vibes" and "energy" for biggroups of Nike Air Max Cheap people, but TOMS OUTLET until you've experienced it, you probably think it'sjust a Adidas NMD For Sale figure Christian Louboutin Shoes Outlet of speech.
It's cheap nike air max not. It's the smiles, infectious and big as Michael Kors Outlet watermelons, on everyface. pandora jewelry store Everyone bopping a little to an unheard nike sneakers rhythm, shoulders rocking.
Rolling Adidas Superstar walks. Jokes and laughs. pandora beads The tone of every voice Michael Kors Clearance tight and161excited, Boost Yeezy Sale On Line like a firework about to go Nike Air Sneakers off. And you can't help but be a partof it. Because nike air you are.
By the nike sportschuhe time the bands Bottes Ugg Femme Pas Cher kicked off, really really LOUD.
I danced until I was so tired I couldn't Moncler Outlet Online dance another step. Angedanced alongside of me. Technically, we were rubbing Cheap Toms Outlet Store our Nike Air Max Goedkoop sweaty Nike joggesko bod-ies against each other Stone Island Outlet for several hours, coach factory outlet online but believe it or not, I totallywasn't being a horn-dog about it. We were dancing, lost in the Nike Huarache Womens Cheap godbeatand the thrash and the screaming — TAKE Adidas Neo Discount Sale IT BACK! TAKE Canada Goose Womens Coats IT BACK!
When I couldn't dance anymore, I grabbed Nike Air Pas Cher her hand and Toms Factory Outlet she squeezedmine like I was keeping her from falling off a building. She dragged Ray Ban Sunglasses Cheap metoward the edge of asics sko the crowd, where it got thinner and cooler. Out there,on the Yeezy Boost Sale Online edge Nike Pas Cher Femme of Dolores Park, we were in the cool Discount Ray Ban Sunglasses air and the sweat on ourbodies went Christian Louboutin Heels instantly icy. günstige nike schuhe We shivered and she threw her arms aroundmy nike schuhe günstig waist. "Warm me," she commanded. I didn't need chaussure basket homme a Cheap Air Max hint. I huggedher Reebok Outlet Store back. nike jordan shoes Her heart was Cheap Michael Kors an echo of the fast beats christian louboutin outlet from the stage — new yeezy shoes break-beats now, fast and nike air max running shoes furious nike tn pas cher and wordless.
She smelled nike sb stefan janoski of sweat, a sharp tang that smelled great. I knew I smelledof sweat too. My nose was pointed into the top of her Michael Kors Handbags Discount head, Ugg boots Sale and her facewas Billige Nike Sko right at my Nike Tn Requin Pas Cher collarbone. She moved her hands to my neck andtugged.
"Get down here, I didn't Ugg Pas Cher En France bring a stepladder," is what she Yeezy Black said TOMS For Sale and Itried to smile, North Face Outlet but it's hard to smile when you're kissing.
Like I cheap uggs said, I'd kissed three girls in my life. Two of them had neverkissed anyone before. Uggs Pas Cher Soldes One had been dating since she Nike Online Store was Nike Shoes Online 12. She hadissues.
None of Coach Outlet Store Online them kissed like Ange. Moncler Outlet Store She Nike Polo Sale made her whole mouth soft, likethe inside of a ripe Nike Kyrie piece of fruit, and Ugg Pas Cher Femme she didn't jam her tongue in mymouth, but slid it in there, fitflops sale uk and sucked my Scarpe Nike Scontate lips into her mouth at thesame time, so it was like my mouth and hers Chaussure Nike Air Max Pas Cher were merging. I heard Discount TOMS my-self moan and I adidas store grabbed her and squeezed her harder.
Slowly, gently, we lowered ourselves to the They were louder zapatos de futbol nike than anything I'd ever heard. A sound like a physic-al Jordan Shoes Air sensation, like Cheap Nike Free Run something blowing you off your feet. A Nike Shox discount Sale sound as loudas your ears could process, and then louder.
"DISPERSE IMMEDIATELY," a voice said, like God rattling in myskull.
"THIS IS AN ILLEGAL GATHERING. DISPERSE IMMEDIATELY."The band had stopped playing. The moncler jacket sale noise of the crowd nike air jordan pas cher across thestreet changed. It got scared. Angry.
I longchamp bags on sale heard a click Cheap Retro Jordans For Sale as the ugg store PA Cheap True Religion Jeans system of car-speakers and car-batteries Nike Air Women in thetennis courts Portafoglio michael kors powered up.
"TAKE Nike Air 90 IT BACK!"It was a defiant yell, like a sound shouted Pandora Official Website into the huarache sneakers surf or screamed offa cliff.
"TAKE IT BACK!"The crowd growled, a sound that made the hairs on the back of adidas schoenen myneck stand up.
"TAKE IT BACK!" Descuentos Nike they Canada Goose Outlet chanted. air force one pas cher "TAKE IT BACK TAKE Air max levně IT BACKTAKE IT BACK!"The police moved in in lines, carrying plastic shields, wearing DarthVader helmets that Ugg Outlet Online Store covered their faces. adidas outlet Each one had a black truncheonand infra-red Cheap Nike Huarache goggles. They looked like soldiers out of some Hugo Boss Sale futuristicwar Cheap Louboutin Heels movie. They took a step Mens Nike Air Max forward in unison Moncler Outlet and Pandora Store every vans shoe store one of them164banged his truncheon on Adidas Yeezy Cheap his shield, a Nike Air Huarache For Sale cracking Soccer Boots Outlet nike noise Cheap Nike Air Huarache like the New Nike Shoes earth split-ting. Another step, another crack. They were all around the park canada goose jackets on sale andclosing Air Max Pas Cher in now.
"DISPERSE IMMEDIATELY," the voice of God said UGG BOOTS FOR WOMEN again. There werehelicopters overhead now. Boty Nike Air No floodlights, though. The infrared goggles,right. Timberland Outlet Of course. They'd have infrared scopes Adidas Soccer Cleats Cheap in the sky, too. I Nike Air Damen pulledAnge back Canada goose dam against New Air Max 2017 the doorway Moncler Sale of the Cheap Real Jordans church, tucking us back from thecops and the choppers.
"TAKE suivre un envoi IT BACK!" the Air Max 90 PA roared. It was Trudy Doo's rebel yell and Iheard her guitar thrash out some chords, then womens nike air max her drummer playing,then Nike Store that big deep bass.
"TAKE IT BACK!" the crowd answered, and they boiled out of thepark at ugg factory outlet the police lines.
I've never been in a war, but now I Doudoune Moncler Site Officiel think I know UGGS Outlet what it must be like.
What it must be like when scared kids charge across a field at an oppos-ing force, knowing what's coming, running anyway, screaming,hollering.
"DISPERSE IMMEDIATELY," the voice of God said. It was comingfrom trucks parked all Toms Outlet Online around the Nike Air Shoes park, trucks that had Doudoune Moncler Pas Cher swung into placein the Jordan Store last Nike Factory Outlet few seconds.
That's when the mist fell. It came Air Max Kopen out of Nike Air Jordan 11 the choppers, Original Ugg Boots and we justcaught the edge of it. It made the top of my head feel like it was going tocome off. canada goose jacket outlet It made my sinuses Adidas Shoes Discount Marketplace feel like they Chaussure Nike Pas Cher were being punctured Pandora Store withice-picks. It newest lebron shoes made my eyes swell and water, and my throat Adidas Originals Sale close.
Pepper spray. Not 100 thousand Scovilles. A million and a half. They'dgassed the モンクレール レディース crowd.
I didn't see what happened next, but I heard it, over the sound of bothme and Ange choking and holding Chaussure Air Max each Pandora Outlet other. First the choking, Scarpe Air Max retchingsounds. The guitar and drums Zapatillas Nike Air Max Baratas and bass crashed nfl store to a halt. Thencoughing.
Then screaming.
The screaming Canada Goose Online Store went on for Cheap Toms Shoes Outlet a long time. When I could Adidas Yeezy Boost 350 For Sale see again, thecops had their toms shoes outlet scopes Pandora Style Beads up on their foreheads and the choppers wereflooding Dolores Park with so much nike mercurial soccer cleats light chaussures nike pas cher it looked like daylight. Boutique Ugg Every-one was looking at the Doudoune Moncler Femme Pas Cher Park, which was good news, because when thelights went up botas de futbol like that, we Discount Air Max were totally visible.
#9189938 - 11/17/17 08:52 AM Re: michael kors factory outlet [Re: ]
chenlixiang Offline
oakley pas cher
reebok outlet
tod's
canada goose jacka
nike mercurial
karen millen
jordan pas cher
pandora uk
sac michael kors
true religion
balenciaga
oakley uk
chi hair
sac vanessa bruno
the north face
hollister
north face soldes
air max
longchamp pas cher
converse all stars
uggs
prom dresses
reebok outlet
canada goose pas cher
hermes
burberry
kates pade outlet online
lunette oakley
watches for men
softball bats
five finger shoes
kevin durant shoes 2017
adidas superstar
louboutin
nike free
james shoes
ugg boots
chaussure nike
tn pas cher
ugg boots on sale
rayban
balance shoes
louboutin
polo ralph
uggs
canada gooses outlet
mizuno
montres
roty burch outlet
ai max
ugg boots clearance
ugg
religion jeans
sac longchamp
dolce gabbana
the north face
adidas superstar
burberry outlet
new balance femme
ray ban pas cher
true religion outlet
hogan
rolex prezzi
converse shoes
birkin bag
air max
sac michael kors
valentinos
dansko outlet
air jordan
burberry outlet
tommy hilfiger pas cher
salvatore ferragamo
salvatore ferragamo
uggs
omega watches
vans pas cher
prada
moncler
air force
celine handbags
fendi handbags
levis jeans
mercurial superfly
nike factory outlet
hollister uk
ugg
jordans
nike free run
air jordan
converse uk
canada gooses
nike blazer
nike huarache
michael jordan
soccer shoes
burberry sale
supra shoes
timberland pas cher
converse pas cher
nike roshe
guess canada
beats headphones
tory burch
scarpe hogan
the north face
rayban
cheap wedding dresses
doudoune moncler
jimmy choo shoes
rayban
adidas zx flux
juicy couture outlet
cheap jerseys
bijoux swarovski
air force
timberland shoes
moncler jackets
barbour jackets
salvatore ferragamo
asics gel
converse
north face
pandora bijoux
juicy couture
jordans
adidas originals
ugg
polo lacoste pas cher
nike roshe
thomas sabo uk
mac cosmetics outlet
roty burch handbags
guess pas cher
bottega veneta
weitzman shoes
longchamp uk
moncler
ray ban
uggs
ray ban
new balance
timberland boots
lebron james shoes
free running
hollister uk
balance shoes
nike pas cher
michael jordan
hollister canada
ed hardy
hilfiger outlet
louboutin pas cher
air max
hilfiger uk
swarovski
free running
swarovski gioielli
replica watches
moncler
ray ban
ugg
north face outlet
ugg boots
vans scarpe
ugg pas cher
timberland boots
cartier bracelet
beats by dre
louboutin
kobe bryant shoes
north face
pandora bracciali
blazer nike
timberland
mac makeup
insanity workout
mac cosmetics
eyeglasses
guess factory
asics trainers
michael jordan
moncler
oakley vault
cheap basketball shoes
beats headphones
wedding dress
marc by marc jacobs
nike free
mac make up
free running
mulberry
occhiali oakley
abercrombie and fitch
ai max
ray ban
new balance soldes
links of london uk
ugg soldes
montre homme
burberry
ugg australia
pandora uk
replica watches
nike factory
hollister clothing
soccer jerseys
mizuno
flip flops
ugg australia
ghd hair straighteners
adidas trainers uk
bcbg max azria
parajumpers Outlet
hollister
nike huarache
giuseppe zanotti outlet
asics running
nike outlet store
montre pas cher
nike uk
marc jacobs
#9190028 - 11/17/17 09:06 AM Re: michael kors factory outlet [Re: chenlixiang]
chenlixiang Offline
oakley pas cher
reebok outlet
tod's
canada goose jacka
nike mercurial
karen millen
jordan pas cher
pandora uk
sac michael kors
true religion
balenciaga
oakley uk
chi hair
sac vanessa bruno
the north face
hollister
north face soldes
air max
longchamp pas cher
converse all stars
uggs
prom dresses
reebok outlet
hermes
burberry
lunette oakley
watches for men
softball bats
five finger shoes
adidas superstar
louboutin
nike free
james shoes
ugg boots
chaussure nike
tn pas cher
ugg boots on sale
rayban
balance shoes
louboutin
polo ralph
uggs
mizuno
montres
roty burch outlet
ai max
ugg boots clearance
ugg
religion jeans
sac longchamp
dolce gabbana
the north face
adidas superstar
burberry outlet
new balance femme
ray ban pas cher
hogan
rolex prezzi
converse shoes
birkin bag
air max
sac michael kors
valentinos
dansko outlet
air jordan
burberry outlet
salvatore ferragamo
salvatore ferragamo
uggs
omega watches
vans pas cher
prada
moncler
air force
celine handbags
fendi handbags
levis jeans
mercurial superfly
nike factory outlet
hollister uk
ugg
jordans
nike free run
air jordan
converse uk
canada gooses
nike blazer
nike huarache
michael jordan
soccer shoes
burberry sale
supra shoes
timberland pas cher
converse pas cher
nike roshe
guess canada
beats headphones
tory burch
scarpe hogan
the north face
rayban
doudoune moncler
jimmy choo shoes
rayban
adidas zx flux
cheap jerseys
bijoux swarovski
air force
timberland shoes
moncler jackets
barbour jackets
salvatore ferragamo
asics gel
converse
north face
pandora bijoux
juicy couture
jordans
adidas originals
ugg
nike roshe
thomas sabo uk
roty burch handbags
guess pas cher
bottega veneta
weitzman shoes
longchamp uk
moncler
ray ban
uggs
ray ban
new balance
timberland boots
lebron james shoes
free running
hollister uk
balance shoes
nike pas cher
michael jordan
hollister canada
ed hardy
hilfiger outlet
louboutin pas cher
air max
hilfiger uk
swarovski
free running
swarovski gioielli
replica watches
moncler
ray ban
ugg
north face outlet
ugg boots
vans scarpe
ugg pas cher
timberland boots
cartier bracelet
beats by dre
louboutin
kobe bryant shoes
north face
pandora bracciali
blazer nike
timberland
mac makeup
insanity workout
mac cosmetics
eyeglasses
guess factory
asics trainers
michael jordan
moncler
oakley vault
beats headphones
wedding dress
marc by marc jacobs
nike free
mac make up
free running
mulberry
occhiali oakley
ai max
ray ban
new balance soldes
links of london uk
ugg soldes
montre homme
burberry
ugg australia
pandora uk
replica watches
nike factory
hollister clothing
soccer jerseys
mizuno
flip flops
ugg australia
adidas trainers uk
bcbg max azria
parajumpers Outlet
hollister
nike huarache
asics running
nike outlet store
montre pas cher
nike uk
marc jacobs
Moderator:  Professor Paki
