#1869356 - 09/18/07 07:03 PM
Brake Rotor and Pad combo's - lessons learned / experiences
foca
Loc: West Palm, FL
looking for a pad and rotor combo that has worked for someone. 00 Si that sees daily street, with occasianal SCCA solo.
Looking for: 1. slightly better performance/quality than stock 2. ~$200 for the front set of rotors and pads 3. longevity
I do not want pads that are gonna gouge my rotors and render them useless in a year, don't care how good they stop. I don't want warped rotors in a couple years either. I want to go through 1 or almost 2 set of pads before I deal with having to replace rotors again. Need a combo that works. do not want to have incompatible pads / rotors.
Honda OEM would be an option, but they are not the best either. honda rotors of this vintage seam to warp early too.
companies I am considering so far for rotors (slotted): ATE Brembo Powerslot
pads: ATE Premium One (ceramic) Hawk Perf (Ceramic)
please only speak on experience. no he-said-she-said or i-read-sport-compact comments. Please do not echo some comment from a forum, as most forums are about 95% BS'ers anyhow.
Hoping the track guys can help me out with this.
Thanks fellas.
Santiago
EK Coupe, B16B
#1873306 - 09/19/07 05:35 PM
Re: Brake Rotor and Pad combo's - lessons learned / experiences
[Re: FBP EM1]
foca
Loc: West Palm, FL
thanks fbp.
I will check my rears again, but i do not think I need them right now.
Santiago
EK Coupe, B16B
#1873309 - 09/19/07 05:37 PM
[Re: foca]
foca
Loc: West Palm, FL
fbp,
how long have you had this set on?
is it an EK Si?
Santiago
EK Coupe, B16B
#1880439 - 09/21/07 07:20 PM
[Re: Mr. Knowitall.]
foca
Loc: West Palm, FL
never go back to HPS??
why. what advantage have you felt with the + ??
thanks.
Santiago
EK Coupe, B16B
#1881494 - 09/22/07 10:45 AM
Hemix
Less fade during aggressive street driving.
You must be doing some seriously aggressive street driving. I've done some pretty steep grade canyons with mine and no brake fade.
"Great scientific achievements are not made by a genius saying 'Eureka'. Great scientific achievements are made by a confused man saying, 'What the f***?'" -Matthew Tearle
#1881752 - 09/22/07 01:20 PM
Billy Bibbit
Loc: Indiana
i had this set up for a while and proved to do very well for the average daily / autox car
*Rotora Slotted rotors *Axxis ulimates(front) *Autozone blanks and duralast pads(rear only) *Motul RBF600 fluid
now you wont need fluid that expensive and blanks all the way around would be fine. i have now upgraded to hawk HPS+ pads all the way around due to more track time/autox time. there awesome if you dont mind the dust and the noise from the pad(its like a dump truck at times)
#1892101 - 09/25/07 07:47 PM
[Re: foca]
Bo Mook
The Mooks of Haztard
Loc: county
i always ran brembo oe rotors and akekbono ceramic pads.
you don't need more than that for street.
#1903840 - 09/29/07 01:51 PM
[Re: Bo Mook]
greenmaxse
Loc: Connecticut
EM1 Brembo blanks HP + pads Honda fluid bled monthly My Experiences: please excuse the long post My car is used exclusively for autcross. I still drive it to events, and on nice days, but it's my toy rather than a daily. I've had this setup for ~7k miles, and the pads are more than 90% left, the rotors like new. I will warn the pads dust horribly, and do have some vibrations, however once they're hot they grab well. They have taken me to a Solo II HS championship in my local club, and they still work well on the street. For strickly street I would recommend the HPS, I've used those and they are very nice, I've never really left their effective range on the street, and they are light on the dust, but they don't match the + stopping power. I would use no other than brembo blank rotors, you can even get them at NAPA. If your local napa says they can't, pm me and I'll get you the part numbers, I managed a napa for a few years. Honda fluid is great for street and solo, only if you use your car for track days and don't flush the fluid regularly would I suggest anything else (motul recommended there, or ate super blue). Hope this helps
If you aren't shifting, you're just riding.
#1912167 - 10/02/07 12:06 PM
[Re: oni]
greenmaxse
Loc: Connecticut
Power Slot rotors (front & rear) Hawk HPS pads Honda fluid Just remember, your brakes don't mean shit if your tires suck.
That's very true-tires stop your car, not brakes. I run 205/50/15 azenis rt-615s, and I fight lockup regularly on the course. On a side note though-the response of the pads make it easier to modulate, thus keeping the tires at maximum effectiveness. R-comps make the car stop like a lotus. Also find out what class you want to run. Braided lines or any slotted/drilled or different weight/material of rotor will take you out of stock class and into sts. You can use any pads/fluid though.
#1926150 - 10/07/07 05:00 AM
[Re: FCobra94]
dunce11r
chaturbate stalker
Loc: Cali
i used to use the HPS, but will never use again... i went axxis ultimates, and never looked back... even though they dust like hell.. but so did the HPS... jsut a notch less.
#2298513 - 02/05/08 10:49 PM
CivicRacerExR
Loc: Landisville, PA, USA
On my 00 Civic Si for STS SCCA Class I ran the following:
00-03 Brembo blanks AEM pads Goodrich Stainless steel lines Valvoline Synpower Brake Fluid
When I did a track day at VIR I had serious brake fade on my final class room session. Which was expected with AEM pads and Brembo blanks. The air bleed itself out on the way home though.
04-06 - I was sponsored by Rotora and got all this free. Rotora Brake slotted rotors Axxis Ultimate pads
I was mildly surprised on the rotor and pad combination when I picked up sponsorship from Rotora. Did some lapping days with no problems of fade.
Sponsored by: KAM Racing Sports, Falken Tires, Progress Technology, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!Autocross Help PageBuy my Civic parts!
#2435886 - 03/14/08 06:02 AM
[Re: foca]
peyo
Axxis Ultimate Brembo Rotor Drilled (front/rear) Honda Fluid Stock Brake line
Now, I'm trying to change with: EBC Yellow (my friend use it and its damn good!) Motul (Is it gonna make big different?) Goodridge Brake Line Kit (I donno if this works good or just wasting my money)
Just try to brake!!!
#2505902 - 04/03/08 05:52 PM
[Re: Runnin@Redline Jr]
peyo
Just quick question..Anyone suggested using Motul 5.1 (its non sillicone base)and using goodridge ss brake line on that?
#8990346 - 03/31/17 03:08 AM
[Re: peyo]
hyhms
#9087028 - 07/24/17 04:48 AM
[Re: hyhms]
HYst
ces nike sb stefan janoski brutales pandora beads facéties et sous Nike Air Huarache For Sale cette forme Michael Kors Handbags Discount grossière, c’étaient nos Air Max Kopen craintes Nike Air Max Sale que Air max levně nous retrouvions, newest lebron shoes celles Air Jordan Retro Sale qui faisaient le New Air Max 2017 sujet Michael Kors Clearance de nos Yeezy Boost Sale Online entretiens dans Air Max 90 le milieu Hugo Boss Sale ? gouvernemental Louboutin Wedding Shoes ? Toms Factory Outlet des Saintes-Maries, Cheap Retro Jordans For Sale – Cheap Michael Kors Handbags comme nous suivre un envoi disions, par habitude. Nike Air Sneakers Et Pandora Store si je reebok running shoes m’abstenais d’en new yeezy shoes parler avec longchamp bags on sale Raymonde, lorsqu’après la journée de Nike Air 90 travail ugg clearance nous flanions dans Christian Louboutin Shoes Outlet l’exquise douceur de la nuit Nike Roshe Run méditerranéenne, Nike Air Women au long de Chaussure Air Max la günstige nike schuhe plage déserte, TOMS OUTLET ces appréhensions ne Nike Roshe Run Sale nous hantaient que Nike Pas Cher Femme trop, et Scarpe Air Max silencieux soudain, nous resserrions notre étreinte frissonnante vans shoe store en Jordan Sneakers For Sale voyant Nike Air Pas Cher monter à l’horizon nike tn pas cher sud, Nike Factory Store proche d’Antarès du Scorpion, Nike Soccer Cleats Boots la sanglante chaussure basket homme topaze nike shoes de Mars.
CHAPITRE Adidas Yeezy Boost 350 For Sale II
ISAAC SCHLEMIHL, TRUSTEUR toms sale DES Adidas Originals Stan Smith SOVIETS
Si le rétablissement du Zapatillas Nike Air Max Baratas Directoire Kobe Shoes Nike dans sa suprématie politique demeurait Adidas Soccer Cleats Cheap un TOMS For Sale rêve lointain, nike air les conditions Air Nike matérielles où vivaient Zapatillas Air Max ses membres s’étaient Sac a main michael kors améliorées. Ugg boots Sale Les Adidas NMD For Sale deux h?tels leur Discount Christian Louboutin Shoes étaient entièrement zapatillas nike baratas réservés, et nfl store le village des Saintes-Maries, fier d’héberger Ladislas Boty Nike Air Wronsky Cheap Toms Outlet Store et botas de futbol les autorités spirituelles christian louboutin outlet du monde-pensant, Timberland Outlet éliminait billige nike sko de ses murs les réfugiés du commun et Canada Goose Outlet les gens suspects Billige Nike Sko d’opinions subversives. L’infatigable Leduc ravitaillait, en dépit de adidas outlet difficultés croissantes, notre Uggs Pas Cher Soldes Versailles lilliputien ; M. Canada goose dam Van Gulden, Pandora Store en sa qualité d’ex-ministre du Trésor, parait tant Cheap Nike Air Huarache bien Canada Goose Outlet que Discount Ray Ban Sunglasses mal au problème Yeezy Black financier.
Mais le Chaussure Nike Air Max Pas Cher progrès le prada outlet plus net concernait notre sécurité, Mens Nike Air Max si mal Yeezy Shoes Discount Marketplace assurée Pandora Outlet le ugg factory outlet premier jour par womens nike air max les cinq Cheap Michael Kors Tote Bag gendarmes locaux. Nike Huarache Womens Cheap Huit cents Sénégalais échappés à la Nike Shox discount Sale destruction retro jordans for cheap de Christian Louboutin Heels Marseille, Official NHL Jerseys aux fureurs de Official Toms Shoes Outlet l’anarchie Cheap Air Max ou à la contagion révolutionnaire, – venus Moncler Jackets Discount Marketplace d’eux-mêmes Ugg Pas Cher En France s’offrir, ou New Nike Shoes racolés dans la air force one pas cher région nike jordan shoes (certains même Adidas Yeezy Cheap en Afrique) par les envoyés de Leduc, – Ugg Pas Cher Femme montaient Jordan Shoes Air une garde Soccer Boots Outlet nike vigilante et Cheap True Religion Jeans dévouée Doudoune Moncler Pas Cher autour Ugg Outlet Online Store de notre goedkope nike air max asile, sanctuaire suprême de l’Ordre Canada Goose Womens Coats et de la Cheap Real Jordans Civilisation.
Le spectacle était réconfortant, de voir adidas store tous ces superbes noirs en Michael Kors Outlet uniforme blanc Nike Shox Cheap à casque colonial évoluer martialement sur l’esplanade Nike joggesko du camp de hangars voisin Moncler Outlet Online de la coach factory outlet online T.S.F., Chaussure Nike Pas Cher s’exercer à la zapatillas running man?uvre des anti-aériens, ou à Nike Free Run 5.0 Womens l’embarquement rapide à cheap nike air max bord Air max dam de nos dix rotatifs Moncler Outlet Store de guerre, laqués de blanc, hogan scontate aux armes Toms Outlet Online du Directoire ! Scarpe Nike Scontate Nous n’étions Nike Air Jordan 11 certes plus Michael Kors à la merci Doudoune Moncler Femme Pas Cher d’un coup UGG BOOTS FOR WOMEN de main. Il moncler jacket sale aurait Adidas Neo Discount Sale fallu, pour venir Nike Shoes Online à bout de notre défense, une véritable armée.
Un matin Negozi Pandora vers Jordan Shoes For Cheap dix heures, des sonneries Nike Tn Requin Pas Cher de clairon cheap uggs for women insolites, pandora outlet store des commandements Cheap Nike Huarache précipités, les ronflements new pandora charms de Pandora Style Beads la zapatilla adidas flotte aérienne Cheap Air Max Trainers prenant son essor, les ADIDAS NMD SALE ON LINE beuglements Adidas Superstar Sale Online des mégaphones Pandora Store Sale : Pandora Official Website ? Ohé モンクレール レディース ! Adidas Superstar les ugg store rotatifs Nike Shoes Sale Store ! Air Max Pas Cher Halte-là nike air max running shoes ! Défense de survoler nike schuhe günstig ! Passez nike air jordan pas cher au large Jordan Store ou l’on tire… Boutique Ugg ? Je courus Descuentos Nike à Air Max Sneakers la fenêtre de Jordan Schoenen mon bureau.
Bizarres chauves-souris Adidas Originals Superstar noires dans Nike Zapatos le Vans Black Sneakers bel azur d’été, North Face Outlet trois Cheap True Religion Jeans rotatifs à Coach Bags On Sale la Tête-de-Mort, Nike Air Max Goedkoop planaient face à nos Nike Online Store blancs oiseaux Soccer Boots Outlet nike rangés en demi-cercle… Nike Outlet Comment osaient-ils ?… Nike Air Damen Mais une Adidas Shoes Discount Marketplace voix gutturale TOMS SHOES OUTLET et puissante Discount TOMS de Cheap Louboutin Heels haut-parleur cria d’en haut :
— nike sportschuhe Amis ! C’est le camarade zapatos de futbol nike Isaac Air Max Femme Schlemihl qui Original Ugg Boots prie les Hyperdunk 2014 camarades nike sneakers Gédéon scarpe nike Botram nike mercurial soccer cleats et Ladislas Wronsky de lui chaussures nike pas cher accorder canada goose jackets on sale une audience Boost Yeezy Sale On Line !
— Atterrissez derrière les Uggs For Cheap antennes Doudoune Moncler Site Officiel !
Mais converse store la Cheap Toms Shoes Outlet sonnerie Ray Ban Sunglasses Cheap du Portafoglio michael kors téléphone m’empêcha d’en Nike Store voir pandora jewelry store davantage. Le Ma?tre Moncler Sale me 23 IS BACK Store mandait fitflops sale uk à cheap uggs son canada goose jacket outlet bureau.
Je l’y huarache sneakers trouvai en compagnie du ? Sauveur du Monde new jordan releases ?.
— Mettez-vous ジョーダン スニーカー là, Rudeaux, me dit ce dernier. Vous sténographierez Yeezy Men la conversation… Que peut Nike Shoes Discount Marketplace bien nous vouloir ce Sémite Ray Ban Sunglasses Online ?…
Un bruit adidas schoenen de Hogan Outlet pas Discount Air Max militaires toms shoes outlet retentit dans le couloir. Bottes Ugg Femme Pas Cher Le Sémite apparut, Abercrombie and fitch store encadré Nike Air Max Cheap de Adidas Originals Sale Sénégalais chaussure Nike homme et suivi Stone Island Outlet de deux louboutin heels per
Moderator: Huggy, Runnin@Redline Jr, Professor Paki
