#2192940 - 01/05/08 10:51 AM Driver side window will not go up
TxGator Offline
Loc: Atlanta
Hey Guys,
I have a 99 civic ex 2-door. I went to the ATM the other night to get some cash, so I put my window down to use it. When I tried to put it up, it would only go up about half-way. I had also noticed that the rear part of the window was not aligned on its normal track. I tried to force the window back on its track while putting it up, and I managed to get it about an inch or so from the top. I called up the Honda dealer and they want to charge $96 just to look at it.
Is there anything I could try to fix it before I take it to the dealership? Thanks.
ITS GREAT TO BE A FLORIDA GATOR!!
#2193301 - 01/05/08 01:35 PM Re: Driver side window will not go up [Re: TxGator]
Renaissanceman Offline
this happens all the time. u gotta take the panel off (not hard to find the 5 somethign screws) Then reallign the window and use lube. Silocone based? right guys? I'd lube both passenger and driver side windows or else one window will be faster then the other(if you care) It happened once to me when it was fuckin snowing. Fixed it and never happened again. goodluck.
Edited by Renaissanceman (01/05/08 01:38 PM)
#2196132 - 01/06/08 09:13 PM Re: Driver side window will not go up [Re: Renaissanceman]
00civicsiboy Offline
Loc: Tennessee
Will lube properly fix the problem?
Edited by 00civicsiboy (01/06/08 09:14 PM)
AIR ASSAULT!!
#2199000 - 01/07/08 04:59 PM Re: Driver side window will not go up [Re: 00civicsiboy]
kyden Offline
Loc: Providence, RI
sometimes it will fix it. but other times the regulator is bent, so you'd have to replace it if so.
#2199181 - 01/07/08 05:59 PM Re: Driver side window will not go up [Re: kyden]
Loc: Tennessee
How much does the regulator cost? The reason is that I had it pop out twice in the past week and I made sure the track was straight..
Any clue?
AIR ASSAULT!!
#2202163 - 01/08/08 11:34 AM Re: Driver side window will not go up [Re: 00civicsiboy]
mhart Offline
Loc: central pa
my si does this all the time, here is what i found hope it opens for you.
http://www.hondaautomotiveparts.com/auto...ry5=DOOR+WINDOW
#2204660 - 01/08/08 10:46 PM Re: Driver side window will not go up [Re: mhart]
Loc: Tennessee
140 for a motor...Yikes!
AIR ASSAULT!!
#2206381 - 01/09/08 11:38 AM Re: Driver side window will not go up [Re: 00civicsiboy]
mhart Offline
Loc: central pa
the regulator is only 50.
#2213487 - 01/11/08 01:11 AM Re: Driver side window will not go up [Re: mhart]
Loc: Tennessee
How easy of an install is a new regulator?
AIR ASSAULT!!
#2226164 - 01/15/08 07:48 AM Re: Driver side window will not go up [Re: 00civicsiboy]
99redSiR Offline
Loc: Hamilton Ontario
man this used to always happen to me.. it was such a bitch.. i ended up lubing up the rubber and bending the track a bit and havent had any problems since.. hope you get urs fixed.. cause its a really annoying problem
"You either die a hero, or live long enough to see yourself become the vilian"
#2232874 - 01/16/08 08:14 PM Re: Driver side window will not go up [Re: 00civicsiboy]
OGtripleOG Offline
Not too hard if you're mechanically inclined.
#2246033 - 01/21/08 08:01 AM Re: Driver side window will not go up [Re: OGtripleOG]
MyFirstSpoon Offline
....was a 12" dildo
mine did that as well, pain in the ass!
mad tyte jdm.
#2247647 - 01/21/08 04:26 PM Re: Driver side window will not go up [Re: Renaissanceman]
iPood Offline
Loc: Green Bay, WI
I've had to fix this myself twice already with my car. There is a chance that the tracks the window is on just loosened up which caused the window to pop off of them. To fix it, first you need to remove the door panel. Then get the window back on the tracks and then tighten the bolts that hold the tracks in place. Thats what i did the 2nd time it popped off and my window has been fine since.
The biggest pain in the ass is getting the door panel back on perfect, anyway, good luck.
#2248195 - 01/21/08 07:05 PM Re: Driver side window will not go up [Re: iPood]
98PredatorCivic Offline
Loc: Prince Frederick, MD
This has also happened to me in the past on my 98EX, I took the panel off and used some white lithium grease on the track and put the window back on track and tightened up the 10mm bolts at the top and bottom extra tight. Never had a problem thereafter.
Custom Vinyl Graphics/Stripes and Powdercoating
2007 Trailblazer SS 400hp/400tq
2001 Honda Civic EX
1997 Dodge Viper GTS Built and Tuned by Underground Racing Paxton Supercharger, built engine, stage 3 heads, custom cam, Roller Rockers, Bellenger Headers, Hi-flow cats , Corsa , UGR twin fans w/polished shroud, Mc Leod twin disc clutch&flywheel, AEM EMS, UGR Fuel System w/billet rails,3 walbro 255 HP pumps on billet hanger, twin crank case ventilation system, Water Meth 15-17 lbs boost
Moderator:  Dr. BrokenLimits, A_Mantis, Bew, Professor Paki
