#2299927 - 02/06/08 11:24 AM
First dyno run
RAFA_VTK
i just bought my 95 coupe a swap a b16a in it .... i hay intake dc sport header fuel presure regulator civic tipr r pistons exaust 2 1/4 skunk 2 intake manifold skunk 2 camgears and my best run was
160whp & 111 tq
opinions to make my vic run better
#2302028 - 02/06/08 07:47 PM
Re: First dyno run
[Re: strsi]
RAFA_VTK
well i dont have a hondata reflash but we are using chrome its pretty similar to the hondata reflash so far im happy with the results because i dont have head work stock engine block etc the only thig tha the car has its type r pistons. now im planning on buying skunk 2 cams stage 2 so like i said any recomendation so i can improve the whp are welcome
#2307909 - 02/08/08 02:12 PM
Re: First dyno run
[Re: strsi]
RAFA_VTK
ok this is the first time owning a b series so im kind of new on this i dont want to sound ignorant but when you mention s2s2 on a b16 i dont know the meaning so if you can explin that to me so that way i will do the right thing to gain a few whp on my vic
#2311154 - 02/09/08 09:54 PM
Re: First dyno run
[Re: strsi]
RAFA_VTK
ok.... thanks for the info so a little question witch off those two s2s2 or the bc3 im going to get more hp? right know i have ctr cams im planing on selling those and a vafcII and buy one off those brands after that some pulls at the dyno hopefully at least and if im lucky hit 170 whp what do you think ??
#2311937 - 02/10/08 07:43 AM
Re: First dyno run
[Re: strsi]
RAFA_VTK
ok....in your signature i saw that your car hit 185whp thats my goal.someone told me with the mods that i have i was supose to get more hp out of it and to be honest i was expecting that so here its the list off all my mods in my vic. intake short ram fuel presure reg dc sport header4-2-1 ctr cams skunk 2 intake mani skunk 2 camgears ctr pistons magnaflow 2 1/4 exau tunned with chrome all that = 160whp 110 tq all the way to 8500rpm
#2312295 - 02/10/08 11:57 AM
Re: First dyno run
[Re: RAFA_VTK]
RAFA_VTK
i forgot lightweight flyweel act clutch crower spring&retainers
#2312419 - 02/10/08 12:53 PM
Re: First dyno run
[Re: RAFA_VTK]
strsi
Loc: CA
my setup is...
USDM B16 @ ~10.8:1 CR with;
Skunk2 Stage1 Cams & Cam Gears Alaniz Street Master Head Work Omnipower valvesprings, retainers, & valves Mugen headgasket Apex N1 exhaust ITR throttle body Skunk2 Intake Manifold Hondata IM gasket Hondata s200
Plus... Green line- DC 4-2-1 header, no cat, J's intake Red line- RMF header, high flow cat, J's intake Blue line- RMF header, high flow cat, aem itr cold air intake
for you i'd first recomend getting a better header right now as opposed to cams. u need something with a larger 2 1/2 inch collector. For the price, the jdm integra type r header is hard to beat. pair that with a 200 or 300 cell high flow cat from sms-products.com. (u will not be able to use your existing cat(catalic converter) because it will not fit the larger collector on the header).
I'm not saying this will get you 185, cuz it wont. but you will pick up some good power doing this. the stock sized collector of the dc header really chokes power and so does a stock cat (assuming u have one since u did not mention having a high flow cat or test pipe).
dont be so fixated on a number that you want to hit. all dynos read different.
Edited by strsi (02/10/08 12:54 PM)
2000 EBP Si 181.5whp, 119wtq- All Motor B16
1994 EG Hatch
2000 BMW 328ci
207 Forever- RIP
#2312854 - 02/10/08 03:39 PM
Re: First dyno run
[Re: strsi]
RAFA_VTK
first off all thanks for all the info... that day on the dyno someone told me tha that tha problem im having right now its the exaust im running with 2 1/4 dianeter i should change it to a 2 1/5 he didnt mention the header so you sugest a tipe r header if thats the best way a b16 run well im going to try it.... like i said before thanks for all the info ill be posting the results soon dyno & track.
#2325213 - 02/13/08 08:48 PM
Re: First dyno run
[Re: oni]
RAFA_VTK
ok. i just bought a 68mm tb is it worth it or not because my eyes are looking for for the skunk 2 cams
#2326640 - 02/14/08 10:00 AM
Re: First dyno run
[Re: strsi]
RAFA_VTK
ok the ctr cams are alredy in i just bought a profesional 68mm tb after i change the header i hope to get better numbers at the dyno with 160 whp if i take it to the track what its suposse to be my qm time
Moderator: Runnin@Redline Jr, Dr. BrokenLimits, Professor Paki
