#3259917 - 12/02/08 05:01 PM Brake cooling ducts
Even with Cobra brakes, I still manage to have brake fade when I go to high speed track such as Big Willow. Last time the pedal pressure was pretty good, but it was not biting worth of shit, so the pad was overheating. I still wanted to use HP+, because I did not want to change pads track-side, so the answer was to eliminate fog lights, and rig up brake cooling ducts. Here are some pics I took in process.
The kit came with fog light adapters, and brake ducts from Quantum Motorsports. I also called Pegasus Supply for the hose. I was going to use metal strap to hang the ducts, but ended up not using it at all, because I had to redo everything completely
Now you see them
Now you don't
Duct installed
Fender liner cleared for the hose
This is how I did the first setup, because the hose I ordered was too short. I ended up just passing it right next to the wheel, but as soon as you would start turning in, you would contact the hose, and destroy it. Here is what happened after a week.
I went on Corner-Carvers, and looked around and realized that you have to zip the hose to the strut, to avoid the wheel contact, and pass it above the sway bar under the car, so that no part of the wheel touches the hose. Obviously, a new longer hose had to be ordered
No impressions so far, but there is no contact with the wheel either, so that's a good thing. I've got a track days coming up this weekend, so I should get some seat time, and be able to talk about the brake ducts, and how much they helped, or whether they were no help at all.
#3260275 - 12/02/08 06:36 PM Re: Brake cooling ducts [Re: ReplicaR]
SD91RS Offline
Loc: Bakersfield, CA
Nice, I've been meaning to do this to my car as well. Just need to pick up the brackets.
#3260292 - 12/02/08 06:40 PM Re: Brake cooling ducts [Re: ReplicaR]
Loc: Valley of the Sun
Nice. If you don't mind me asking.......how much did that setup cost? Is that some kind of ram-air setup or cooling splitter underneath the front bumber? I love me a clean SN95 5.0 GT.
#3260445 - 12/02/08 07:38 PM Re: Brake cooling ducts [Re: A_Mantis]
SpcNA[ZX] Offline
Loc: Omaha, Nebraska
Fucking nice, I've been thinking about trying something similar with the Talon. Post up some impressions asap.
'92 Galant VR-4
'93 Nissan 300ZX
#3260665 - 12/02/08 08:21 PM Re: Brake cooling ducts [Re: SpcNA[ZX]]
It was 130 dollars for bracket and hardware and 90 dollars for the hose. I still have some hose left over. Planning on keeping it, in case or more like when I will need to patch the ducts.
The spoiler you see under the bumper is actually off 4th Gen Fbody. I trimmed it and fitted it in place of stock one, because it's like two and a half times as big as stock one. I'm planning on wrapping it all the way around to make an actual functional airdam. In order for airdam to be functional, it should be no higher than 4 inches from the ground. Mine is 2.5.
 Originally Posted By: SpcNA[ZX
]Fucking nice, I've been thinking about trying something similar with the Talon. Post up some impressions asap.
Impressions coming monday. Spending saturday and sunday at Willow Springs.
If you don't have to, don't. It's a pain in the ass to route on a street car, ie something that will see full lock steering.
#3260726 - 12/02/08 08:34 PM Re: Brake cooling ducts [Re: ReplicaR]
PsychoEBPSiR Offline
Loc: Vancity,Canada
very cool ,i need to do that for my car aswell ...was just gonna do some defletor panels on lower control arm to deflect it at the brakes,but those look good and easy install
#3261552 - 12/03/08 01:40 AM Re: Brake cooling ducts [Re: PsychoEBPSiR]
silentfurymm Offline
Loc: SoCal....again
I would actually be really curious to see if any air actually goes INTO the duct. I wouldnt be surprised at all if air pressure on the brake disc side is greater than the front of the car due to swirling under the engine and radiator, so that the net effect at 45mph+ is zero cool air to the brakes.
#3264979 - 12/03/08 11:43 PM Re: Brake cooling ducts [Re: ReplicaR]
SD91RS Offline
Blaine Fab has a pretty good kit for F-bods. Maybe this will help motivate me to start RR'ing again.
http://www.frrax.com/rrforum/index.php?showtopic=10321
#3265056 - 12/04/08 12:14 AM Re: Brake cooling ducts [Re: SD91RS]
Requires log in. Can you copy paste the content?
Quantum Motorsports makes plates for F body as well, but their angle leaves a lot be desired when it's time to route the hose. They do it just to clear the sway bar end link and a few other things, but in doing so, the hose comes out almost straight into the wheel. This is why I'm saying that if you can get a pad which will handle the abuse, I would just do that.
Edit: Just googled Blaine Fab stuff. Looks pretty good. The angle looks pretty decent as well, but I still thing you will have to get creative with the hose route. I'm sure if you search FRRAX you will find a way to lay the hose. I had to search Corner-Carvers to find mine. What I like the most about that setup is that it allows you to close up the hub completely, so you don't lose much of the airflow from the duct.
#3265142 - 12/04/08 12:48 AM Re: Brake cooling ducts [Re: ReplicaR]
Professor Paki Administrator Offline
Duolingo Expert
Track day this weekend? Where?
Im going to get out there next saturday, trying to decide between big willow vs throwing the car around sows. I might get real ambitious and try and hotlap between both the tracks but I'll probably frag something again.
Im surprised you had fade at the big track. I consider it kind of a momentum track because other than one and three you dont need to really stand on the pedal a whole lot. Have you run the roval at cal speedway yet? That will test brakes in a real hurry.
#3265158 - 12/04/08 12:59 AM Re: Brake cooling ducts [Re: Professor Paki]
Doing SOW both days. First one is some private event for BMW owners, basically a huge beginner group. I might help out with instructing if they don't have enough people, but I'm there mostly for tech. Second day is with STUSA, again tech the cars, and get some seat time, work on the lines.
I would get a bit of fade on turn 1 at willow. The car gets real sketchy, and I just want to feel like I'm using brakes, rather than gently slowing down. Everywhere else I'm ok. Did not do Cal. Speedway yet, but I'm building up towards it. Next track is probably Buttonwillow later this month. BTW, did you get AAA membership yet?
#3265266 - 12/04/08 03:09 AM Re: Brake cooling ducts [Re: ReplicaR]
Duolingo Expert
Yep!
I had set it up at the track that day, but they don't allow you to use it for 10 days, Im all set to get towed home again now.
#3266554 - 12/04/08 01:58 PM Re: Brake cooling ducts [Re: Professor Paki]
SD91RS Offline
Taken from Frrax:
OK, the Blaine Fab duct plenums are ready to order. Patterns are made, production alpha fits fine, materials are in stock, I'm cutting and welding all weekend so kits will be ready to ship next week.
All aluminum, TIG welded .100" and .065" thick 6061
New ARP hub fasteners included
3" stainless steel hose clamps included
Install is no more difficult than a hub swap - in fact easier, since the hubs do not need to be removed
Plenums fit tightly (approx 1mm clearance to rotor) to the entire inside diameter of the inner rotor cheek, forcing the cooling air into the internal vanes where it can cool both inner and outer rotor cheeks.
Cooling air also circulates around the hub, and the aluminum plenums act as heat sinks for the critical bearing area of the hub.
Accepts standard 3" brake ducting - ducting not included. Since most cars will already have ducts of some form installed, ducting is not included in the kit, but is available as an option, or may be sourced locally.
Immediate releases will be for 2 models: the LS1 caliper on LS1 upright, and C5 caliper on a LT1 upright using Trackbrackets or similar brackets. Duct plenum kits for other popular brake packages will be released soon. Custom and one-offs available, contact me for a quote
Each kit includes a left and right pair of duct plenums, 8 new ARP hub fasteners of the proper length for the application, two 3" stainless steel band clamps, 8 jam nuts for attachment of the plenums, and installation instructions.
Recommended duct routing and things that help them survive:
shorten swaybar endlink till bar ends are parallel to track, then trim top of bolt end.
Wrap duct with gaffers tape where it passes thru the inner fender liner, where the tire tends to rub, and at the endlink.
Avoid full lock steering
squish the duct about 1/2" at the point where the tire will rub - add a wrap or 2 of gaffers tape here as wear happens
use wheel spacers to increase track width
Duct in pics has been in service for a full CMC season:
#3268602 - 12/04/08 11:45 PM Re: Brake cooling ducts [Re: ]
SD91RS Offline
LOL, I believe that. We'll see about the brake cooling kit for the Hawk, if I decide to run those 11's all around I may be looking into a turn one PS pump first...lol
#3269961 - 12/05/08 01:33 PM Re: Brake cooling ducts [Re: ReplicaR]
theLoon Offline
Loc: MN
Needs more zip ties
I'm a badge whore
#3270179 - 12/05/08 02:48 PM Re: Brake cooling ducts [Re: SpcNA[ZX]]
talons dont turn, why would you need brake cooling? end of the 1/4 mile isnt that hard on em
#3270232 - 12/05/08 03:01 PM Re: Brake cooling ducts [Re: Euphoricuck]
CommonGutterTrash Offline
Ever hear of archer brothers?
*DUDE*
Edited by g96nt (12/05/08 03:04 PM)
Craig R.
2000 9-5 Gary Fisher Wagon
1995 850 T-5R
1996 Galant
AIM = gclipse96
#3270262 - 12/05/08 03:10 PM Re: Brake cooling ducts [Re: CommonGutterTrash]
lol i knew someone would go for it.
they still cant turn
#3272021 - 12/06/08 08:23 AM Re: Brake cooling ducts [Re: Euphoricuck]
allan r Offline
Loc: the land of cheese
Very cool! No pun intended ;\)
tuna on white no crust
#3272082 - 12/06/08 09:21 AM Re: Brake cooling ducts [Re: allan r]
I Live In Canada Offline
Why not just cut weight from the car? Or is it already stripped?
#3274109 - 12/07/08 02:06 AM Re: Brake cooling ducts [Re: I Live In Canada]
If you are talking to me then I will say that this is my daily. This is my high miler daily, that sees on average 23k miles a year (54k since Summer '06) There is no way in hell I'm gutting a daily.
#3274320 - 12/07/08 08:58 AM Re: Brake cooling ducts [Re: ReplicaR]
If you still have cooling issues it looks like you have twice as much surface area in the fog light holes to utalize. You can purchase a horn to touch the inner surface of the fog light hole and and neck down to the OD of the metal tube for your ducting. Just beat up two band geeks and steal their trombones, cut to size, duct tape as necessary to fasten.
#3277798 - 12/08/08 12:54 PM Re: Brake cooling ducts [Re: danl]
Well, back from the track this weekend. I'm glad to say that the ducts are helping a good deal, but the real test will be Big Willow next year. I was getting fade at triple digits, so we will see how well the brakes will work then.
Danl: I recently purchased a large Fluidyne radiator, so that will hopefully take care of my cooling issues. The car was running hot yesterday again, but it never got over 240, so I actually managed to complete sessions this time.
#8984532 - 03/26/17 08:41 PM Re: Brake cooling ducts [Re: ReplicaR]
lcklck16 Offline
20170327lck
http://www.polo-outlet.com.co
http://www.suprashoes.us.com
http://www.mulberrysale.co.uk
http://www.nikeshoes.org.uk
http://www.nikeoutletstore.us
http://www.hermesbirkin.org
http://www.fitflop.in.net
http://www.adidasnmduk.org.uk
http://www.polo-outlet.in.net
http://www.foampositeshoe.net
http://www.niketrainers.me.uk
http://www.herveleger.us.com
http://www.edhardy.us.com
http://www.nikeairmax90.me.uk
http://www.nikefree5.us
http://www.longchampuk.me.uk
http://www.todsoutlet.us.org
http://www.fitflopssale.me.uk
http://www.nikerosheone.us
http://www.mulberrybags.me.uk
http://www.lebronjames.us.com
http://www.kobeshoes.us
http://www.futbol-baratas.com
http://www.airmaxuk.org.uk
http://www.beatsbydrdre.co.uk
http://www.hermesbelts.us.com
http://www.nike-store.org.uk
http://www.nikestore-uk.me.uk
http://www.nikeair-max.me.uk
http://www.pradaoutlet.us
http://www.pradashoes.us
http://www.airmax90.org.uk
http://www.ysloutlet.us.com
http://www.iphone-case.org.uk
http://www.omegawatches.me.uk
http://www.cartier-watches.us
http://www.pandoraoutlet.name
http://www.ugg-outlet.me.uk
http://www.cartier.us.com
http://www.marc-jacobs.us.org
http://www.katespade.org.uk
http://www.nike-airmax2015.us
http://www.cazal.us.com
http://www.ferragamo.eu.com
http://www.fitflopssale.us
http://www.airjordan4.org
http://www.asicsisrael.com
http://www.nikerosherun.me.uk
http://www.cheap-raybans.org
http://www.jordanshoes.us.com
http://www.airforce1.us.com
http://www.toryburch.com.co
http://www.vans-shoes.cc
http://www.airmax90.us.com
http://www.rolex-watches.it
http://www.nike-mercurial.net
http://www.kobe9elite.us.com
http://www.burberryoutlet.ca
20170327lck
#9173924 - 10/31/17 02:55 AM Re: michael kors factory outlet [Re: ]
HYst Offline
#9190017 - 11/17/17 09:06 AM Re: michael kors factory outlet [Re: ]
chenlixiang Offline
oakley pas cher
reebok outlet
tod's
canada goose jacka
nike mercurial
karen millen
jordan pas cher
pandora uk
sac michael kors
true religion
balenciaga
oakley uk
chi hair
sac vanessa bruno
the north face
hollister
north face soldes
air max
longchamp pas cher
converse all stars
uggs
prom dresses
reebok outlet
canada goose pas cher
hermes
burberry
kates pade outlet online
lunette oakley
watches for men
softball bats
five finger shoes
kevin durant shoes 2017
adidas superstar
louboutin
nike free
james shoes
ugg boots
chaussure nike
tn pas cher
ugg boots on sale
rayban
balance shoes
louboutin
polo ralph
uggs
canada gooses outlet
mizuno
montres
roty burch outlet
ai max
ugg boots clearance
ugg
religion jeans
sac longchamp
dolce gabbana
the north face
adidas superstar
burberry outlet
new balance femme
ray ban pas cher
true religion outlet
hogan
rolex prezzi
converse shoes
birkin bag
air max
sac michael kors
valentinos
dansko outlet
air jordan
burberry outlet
tommy hilfiger pas cher
salvatore ferragamo
salvatore ferragamo
uggs
omega watches
vans pas cher
prada
moncler
air force
celine handbags
fendi handbags
levis jeans
mercurial superfly
nike factory outlet
hollister uk
ugg
jordans
nike free run
air jordan
converse uk
canada gooses
nike blazer
nike huarache
michael jordan
soccer shoes
burberry sale
supra shoes
timberland pas cher
converse pas cher
nike roshe
guess canada
beats headphones
tory burch
scarpe hogan
the north face
rayban
cheap wedding dresses
doudoune moncler
jimmy choo shoes
rayban
adidas zx flux
juicy couture outlet
cheap jerseys
bijoux swarovski
air force
timberland shoes
moncler jackets
barbour jackets
salvatore ferragamo
asics gel
converse
north face
pandora bijoux
juicy couture
jordans
adidas originals
ugg
polo lacoste pas cher
nike roshe
thomas sabo uk
mac cosmetics outlet
roty burch handbags
guess pas cher
bottega veneta
weitzman shoes
longchamp uk
moncler
ray ban
uggs
ray ban
new balance
timberland boots
lebron james shoes
free running
hollister uk
balance shoes
nike pas cher
michael jordan
hollister canada
ed hardy
hilfiger outlet
louboutin pas cher
air max
hilfiger uk
swarovski
free running
swarovski gioielli
replica watches
moncler
ray ban
ugg
north face outlet
ugg boots
vans scarpe
ugg pas cher
timberland boots
cartier bracelet
beats by dre
louboutin
kobe bryant shoes
north face
pandora bracciali
blazer nike
timberland
mac makeup
insanity workout
mac cosmetics
eyeglasses
guess factory
asics trainers
michael jordan
moncler
oakley vault
cheap basketball shoes
beats headphones
wedding dress
marc by marc jacobs
nike free
mac make up
free running
mulberry
occhiali oakley
abercrombie and fitch
ai max
ray ban
new balance soldes
links of london uk
ugg soldes
montre homme
burberry
ugg australia
pandora uk
replica watches
nike factory
hollister clothing
soccer jerseys
mizuno
flip flops
ugg australia
ghd hair straighteners
adidas trainers uk
bcbg max azria
parajumpers Outlet
hollister
nike huarache
giuseppe zanotti outlet
asics running
nike outlet store
montre pas cher
nike uk
marc jacobs
