#3293433 - 12/12/08 08:23 PM Tech Q: Consequences of driving with a bad CV joint?
fellfrosch7 Offline
Loc: Las Vegas
When I got the Maxima over 2 years ago, a few months after the CV boot ripped. The grease started leaking out, was splashing all over the fender well. Then a couple of weeks later that side axle started clicking under hard acceleration in 1st-2nd gear. I ignored it and it went away. 20k miles later that boot is still ripped, no more grease (cause it all dried up), axle doesn't make any noise. At some point I bought both new axles with CV joints and boots, but I've been too lazy to replace it since it didn't cause any problems.
So what's the problem? Any bad side effects to driving like this? Recently I changed the brake pads/rotors on the car, and that side (passenger) was down to the metal, the driver's side front had a little bit more life left in it. Is that related?
Running: 99 Maxima SE, 97 240SX SE - All motor
Not running: 90 TSi AWD
#3293680 - 12/12/08 09:47 PM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: fellfrosch7]
david
I'd imgagine the bearings will burn up and fall out.
#3293777 - 12/12/08 10:34 PM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: fellfrosch7]
ewraven Offline
I'm surprised that it has lasted that long. I wouldn't have thought one to go that long with most of the grease thrown out.
That makes me feel better about my Dakota though, I need to replace(wallet mechanic) the drivers side front CV axle and have been putting it off.
#3293818 - 12/12/08 10:54 PM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: ]
Chris92Sc2 Offline
Loc: MI USA
Huh?
#3294289 - 12/13/08 08:32 AM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: Chris92Sc2]
Sooner or later its going to fail and leave you stranded. If your ok with that drive it till it breaks and get it towed home to repair it. When a FWD car breaks an axle you get zero power to the ground, you can't even move an inch. That is unless you have a clutch front diff, but drive it for more than a few feet and you'll burn up the clutches in the trans.
#3294462 - 12/13/08 11:21 AM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: danl]
fellfrosch7 Offline
Loc: Las Vegas
I guess I'll get this taken care of sooner rather than later... Thanks for the advice. \:\)
#3294475 - 12/13/08 11:29 AM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: Chris92Sc2]
david
Huh?
If it is run without grease the bearings will burn up and break into a brazillion little pieces. From there either they will fall out or lock the axle up.
#3294513 - 12/13/08 11:53 AM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: ]
SiGuyUWP Offline
I had a 626 that I drove like that for a winter, it made pretty nasty cracking/thumping noises when it turned. Since I bought the car for $150 I didn't really care, but if it's a daily and you depend on it you should probably fix it.
#3294535 - 12/13/08 12:04 PM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: SiGuyUWP]
Anyone know where to buy the bands and tool to reseal the boot clamp? I have a mix and match of axle parts and would like to start taking broken parts and making good axles out of them.
#3294846 - 12/13/08 03:13 PM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: danl]
pete5332000 Offline
Loc: 7426 Hubbard Avenue, Middleton...
Bands and boots I would imagine you could get at an auto parts store. My buddy is a mechanic and he got the tool to seal the clamp from Snap On. He has no complaints and they were actually reasonably price. I think this is the tool or something close to it that he got.
'00 Civic Si '90 GMC Sierra (broken) '88 Chevy 1/2 ton (fixed) Oh, this is the new, kinder, gentler SvA. None of that sarcastic, hateful, flaming for the sake of flaming crap. We're just gonna discuss tech stuff & get along with everyone. If you like, later on we're gonna toast marshmallows & make smores around a burning barrel of diesel while the diabetics & Atkins freaks sing kumbaya & braid each others' hair. - NOHC
#3294882 - 12/13/08 03:47 PM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: pete5332000]
Submission Offline
Loc: Houston, TX
i bought the Help brand bands when i did the civic. pretty simple to do w/ a flat blade screw driver and some needle nose. i've also used the heavy duty zip ties w/ the metal strip in the middle
#3295220 - 12/13/08 07:35 PM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: Submission]
ewraven Offline
I'm going to have to get some of those bands. I'd had the boot replaced on mine and at first the boot slipped off the hub, he fixed that saying that he hadn't tightened the band enough.
Then the little end around the axle, that band slipped off. The grease blew out. Would the axle have to be dissasembled to repack it with grease? Can I just pull the boot down the axle and put in the grease the best I can?
#3305088 - 12/16/08 08:48 PM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: ewraven]
david
IIRC you just slide the boot down and fill it up with the grease. I don't think it has to be packed or anything like you do with say wheel bearings.
#3305119 - 12/16/08 08:59 PM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: ]
ewraven Offline
That is good to know, thanks for the help.
#3305160 - 12/16/08 09:13 PM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: danl]
CommonGutterTrash Offline
I doubt it's SFI approved, but I use the giant hose clamps.
it makes it easy to fix/replace when needed.
and the clamp thing... clears the transmission, easily.
Craig R.
2000 9-5 Gary Fisher Wagon
1995 850 T-5R
1996 Galant
AIM = gclipse96
#3307256 - 12/17/08 03:15 PM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: CommonGutterTrash]
speaking of cv's...both my front wheel bearings need to be changed. sounds like im driving a tank when i turn
#8978828 - 03/20/17 09:58 PM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: Euphoricuck]
ypMs Offline
nike air max running shoes
Air Max 90
Nike Air Jordan 11
scarpe hogan outlet
ugg clearance
Adidas Originals Superstar
Oakley Sunglasses Cheap
Kobe Shoes Nike
cheap uggs
Air Max Pas Cher
Original Ugg Boots
canada goose jackets on sale
nike mercurial soccer cleats
chaussure Nike homme
zapatillas running
Jordan Sneakers For Sale
toms sale
Pandora Store Sale
Adidas Originals Stan Smith
Canada Goose Outlet
new yeezy shoes
ugg store
Ray Ban Sunglasses Online
moncler jacket sale
Ray ban sale online
Nike Air Sneakers
Nike Shoes Sale Store
Michael Kors
nike schuhe günstig
The official UGG
fitflops sale uk
Canada Goose Outlet
Nike Zapatos
pandora outlet store
air force one pas cher
Nike Online Store
adidas store
Nike Air Women
goedkope nike air max
Coach Bags On Sale
Air Nike
Air Max Sneakers
Adidas Neo Discount Sale
converse store
Hugo Boss Sale
Pandora Store
zapatillas nike baratas
Nike Shox Cheap
new jordan releases
UGG BOOTS FOR WOMEN
Boost Yeezy Sale On Line
nike jordan shoes
zapatilla adidas
ADIDAS NMD SALE ON LINE
religion store
Discount Air Max
pandora jewelry store
nfl store
huarache sneakers
longchamp bags on sale
Negozi Pandora
Nike Roshe Run Sale
nike joggesko
Boutique Ugg
TOMS SHOES OUTLET
abercrombie and fitch store
Jordan Shoes Air
Doudoune Moncler Pas Cher
zapatos de futbol nike
chaussure basket homme
Canada goose dam
Nike Air Huarache For Sale
billige nike sko
Nike Soccer Cleats Boots
Moncler Sale
Uggs Pas Cher Soldes
Michael Kors Outlet
Nike Air Max Goedkoop
botas de futbol
Pandora Official Website
louboutin heels
Ugg boots Sale
Yeezy Black
Hogan Outlet
cheap nike air max
Nike Factory Store
new pandora charms
Cheap Michael Kors
Vans Black Sneakers
Jordan Schoenen
Soccer Boots Outlet nike
canada goose jacket outlet
Nike Air Pas Cher
Scarpe Air Max
nike air jordan pas cher
nike sportschuhe
hogan scontate
Air Max Kopen
Air Jordan Retro Sale
Air max dam
Air max levně
Timberland Outlet
cheap uggs for women
newest lebron shoes
ugg factory outlet
Descuentos Nike
Yeezy Boost Sale Online
Nike Air Max Cheap
Pandora Store
Nike Shox discount Sale
nike sb stefan janoski
Ugg Pas Cher En France
nike sneakers
Ugg Outlet Online Store
Stone Island Outlet
Moncler Outlet Online
scarpe nike
Nike Air Damen
womens nike air max
Air Max Femme
Boty Nike Air
Adidas Superstar
Bottes Ugg Femme Pas Cher
Adidas Superstar Sale Online
Moncler Outlet Store
Ugg Pas Cher Femme
pandora beads
Nike Air 90
chaussures nike pas cher
Canada Goose Womens Coats
reebok running shoes
retro jordans for cheap
günstige nike schuhe
Yeezy Men
official NHL jerseys
Nike Store
Toms Outlet Online
uggs for women
vans shoe store
Nike Pas Cher Femme
Jordan Store
toms shoes outlet
coach factory outlet online
Uggs For Cheap
ypMs 2017.3.21
#8984559 - 03/26/17 08:45 PM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: ypMs]
lcklck16 Offline
20170327lck
http://www.polo-outlet.com.co
http://www.suprashoes.us.com
http://www.mulberrysale.co.uk
http://www.nikeshoes.org.uk
http://www.nikeoutletstore.us
http://www.hermesbirkin.org
http://www.fitflop.in.net
http://www.adidasnmduk.org.uk
http://www.polo-outlet.in.net
http://www.foampositeshoe.net
http://www.niketrainers.me.uk
http://www.herveleger.us.com
http://www.edhardy.us.com
http://www.nikeairmax90.me.uk
http://www.nikefree5.us
http://www.longchampuk.me.uk
http://www.todsoutlet.us.org
http://www.fitflopssale.me.uk
http://www.nikerosheone.us
http://www.mulberrybags.me.uk
http://www.lebronjames.us.com
http://www.kobeshoes.us
http://www.futbol-baratas.com
http://www.airmaxuk.org.uk
http://www.beatsbydrdre.co.uk
http://www.hermesbelts.us.com
http://www.nike-store.org.uk
http://www.nikestore-uk.me.uk
http://www.nikeair-max.me.uk
http://www.pradaoutlet.us
http://www.pradashoes.us
http://www.airmax90.org.uk
http://www.ysloutlet.us.com
http://www.iphone-case.org.uk
http://www.omegawatches.me.uk
http://www.cartier-watches.us
http://www.pandoraoutlet.name
http://www.ugg-outlet.me.uk
http://www.cartier.us.com
http://www.marc-jacobs.us.org
http://www.katespade.org.uk
http://www.nike-airmax2015.us
http://www.cazal.us.com
http://www.ferragamo.eu.com
http://www.fitflopssale.us
http://www.airjordan4.org
http://www.asicsisrael.com
http://www.nikerosherun.me.uk
http://www.cheap-raybans.org
http://www.jordanshoes.us.com
http://www.airforce1.us.com
http://www.toryburch.com.co
http://www.vans-shoes.cc
http://www.airmax90.us.com
http://www.rolex-watches.it
http://www.nike-mercurial.net
http://www.kobe9elite.us.com
http://www.burberryoutlet.ca
20170327lck
#9173984 - 10/31/17 03:26 AM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: ]
HYst Offline
#9190022 - 11/17/17 09:06 AM Re: Tech Q: Consequences of driving with a bad CV joint? [Re: ]
chenlixiang Offline
oakley pas cher
reebok outlet
tod's
canada goose jacka
nike mercurial
karen millen
jordan pas cher
pandora uk
sac michael kors
true religion
balenciaga
oakley uk
chi hair
sac vanessa bruno
the north face
hollister
north face soldes
air max
longchamp pas cher
converse all stars
uggs
prom dresses
reebok outlet
canada goose pas cher
hermes
burberry
kates pade outlet online
lunette oakley
watches for men
softball bats
five finger shoes
kevin durant shoes 2017
adidas superstar
louboutin
nike free
james shoes
ugg boots
chaussure nike
tn pas cher
ugg boots on sale
rayban
balance shoes
louboutin
polo ralph
uggs
canada gooses outlet
mizuno
montres
roty burch outlet
ai max
ugg boots clearance
ugg
religion jeans
sac longchamp
dolce gabbana
the north face
adidas superstar
burberry outlet
new balance femme
ray ban pas cher
true religion outlet
hogan
rolex prezzi
converse shoes
birkin bag
air max
sac michael kors
valentinos
dansko outlet
air jordan
burberry outlet
tommy hilfiger pas cher
salvatore ferragamo
salvatore ferragamo
uggs
omega watches
vans pas cher
prada
moncler
air force
celine handbags
fendi handbags
levis jeans
mercurial superfly
nike factory outlet
hollister uk
ugg
jordans
nike free run
air jordan
converse uk
canada gooses
nike blazer
nike huarache
michael jordan
soccer shoes
burberry sale
supra shoes
timberland pas cher
converse pas cher
nike roshe
guess canada
beats headphones
tory burch
scarpe hogan
the north face
rayban
cheap wedding dresses
doudoune moncler
jimmy choo shoes
rayban
adidas zx flux
juicy couture outlet
cheap jerseys
bijoux swarovski
air force
timberland shoes
moncler jackets
barbour jackets
salvatore ferragamo
asics gel
converse
north face
pandora bijoux
juicy couture
jordans
adidas originals
ugg
polo lacoste pas cher
nike roshe
thomas sabo uk
mac cosmetics outlet
roty burch handbags
guess pas cher
bottega veneta
weitzman shoes
longchamp uk
moncler
ray ban
uggs
ray ban
new balance
timberland boots
lebron james shoes
free running
hollister uk
balance shoes
nike pas cher
michael jordan
hollister canada
ed hardy
hilfiger outlet
louboutin pas cher
air max
hilfiger uk
swarovski
free running
swarovski gioielli
replica watches
moncler
ray ban
ugg
north face outlet
ugg boots
vans scarpe
ugg pas cher
timberland boots
cartier bracelet
beats by dre
louboutin
kobe bryant shoes
north face
pandora bracciali
blazer nike
timberland
mac makeup
insanity workout
mac cosmetics
eyeglasses
guess factory
asics trainers
michael jordan
moncler
oakley vault
cheap basketball shoes
beats headphones
wedding dress
marc by marc jacobs
nike free
mac make up
free running
mulberry
occhiali oakley
ai max
ray ban
new balance soldes
links of london uk
ugg soldes
montre homme
burberry
ugg australia
pandora uk
replica watches
nike factory
hollister clothing
soccer jerseys
mizuno
flip flops
ugg australia
ghd hair straighteners
adidas trainers uk
bcbg max azria
parajumpers Outlet
hollister
nike huarache
giuseppe zanotti outlet
asics running
nike outlet store
montre pas cher
nike uk
marc jacobs
