#871202 - 01/03/07 10:34 PM Crank-scrapers anyone?
OnyxEros Online   nohc
Anyone ever use them or know anyone that does?
Here are mine
#871253 - 01/03/07 10:43 PM Re: Crank-scrapers anyone? [Re: OnyxEros]
We've got a less complicated crank scraper on the race car ('92 BMW 325is).
#871267 - 01/03/07 10:46 PM Re: Crank-scrapers anyone? [Re: OnyxEros]
http://www.crank-scrapers.com ??
I worked with Kevin Johnson to develop the "early" Chrysler 2.4 version. I got a freebie for it, then he sent me the updated version w/ teflon and baffles/trap doors. Its sweet.
#871277 - 01/03/07 10:48 PM Re: Crank-scrapers anyone? [Re: ScottStaypuff]
Yeah Kevin did mine too
I sent him a crank so he sent me the free lower one I had to pay for the teflon one :-)
Nicest guy in the world
#874631 - 01/04/07 07:52 PM Re: Crank-scrapers anyone? [Re: OnyxEros]
So the idea is to reduce windage losses correct?
I always thought that a little more boost would negate the 2hp worth of windage loss personally.
#874795 - 01/04/07 08:47 PM Re: Crank-scrapers anyone? [Re: danl]
RyanTSI Offline
Loc: Canadia
I always assumed they were to keep more oil in the pan for road course cars, to prevent oil starvation. Correct?
#878205 - 01/05/07 05:16 PM Re: Crank-scrapers anyone? [Re: RyanTSI]
reducing windage loss mainly
they have a dyno of an srt4 gaining 7hp and 16tq just adding a scraper on the dyno
#878476 - 01/05/07 06:22 PM Re: Crank-scrapers anyone? [Re: OnyxEros]
Windage to me = good. It means what we have is oil splashing oil onto the rods and piston skirts (mostly rods and cylinder walls though). Oil IMO is the most important coolant. Think about it.
#878688 - 01/05/07 07:36 PM Re: Crank-scrapers anyone? [Re: danl]
it's not the most important coolant on your counter weights which is what a crank scraper works on
#878703 - 01/05/07 07:42 PM Re: Crank-scrapers anyone? [Re: OnyxEros]
I dunno about piston/rod cooling but I do know they free up some horsepower and help with oil starvation in corners with a Neon. At least the one I have does with the extra baffles and trap doors. Good relatively cheap insurance.
Besides its one of the few modifications you can do that doesn't F*ck up NVH or fuel mileage.
#878744 - 01/05/07 08:01 PM Re: Crank-scrapers anyone? [Re: OnyxEros]
How so? Pretty sure the SRT-4 has a scraper stock.
"The oil-pan gasket has tabs that act as an integral crank-scraper for oil control. "
Edited by Impulsive (01/05/07 08:05 PM)
#878752 - 01/05/07 08:04 PM Re: Crank-scrapers anyone? [Re: Impulsive]
Sukkoi18 Offline
Loc: Quad Cities IL/IA
The crank hitting the oil at high RPM can also cause it to foam. Not such a good thing.
Juiced 2002 Z28
Blown 1989 Mustang GT
#878766 - 01/05/07 08:09 PM Re: Crank-scrapers anyone? [Re: Sukkoi18]
Man I'm gonna spin to 9000+ with no scraper FTL.
#878801 - 01/05/07 08:23 PM Re: Crank-scrapers anyone? [Re: Impulsive]
The crank-scrapers.com scraper is much more substantial so I definitely think it should have an advantage.
DanL, I would read the crank-scraper website. I think at 9000rpms you would benefit from one.
#878824 - 01/05/07 08:28 PM Re: Crank-scrapers anyone? [Re: ScottStaypuff]
I'll look into it but only after I run it "normal" for a before and after.
#879156 - 01/05/07 10:19 PM Re: Crank-scrapers anyone? [Re: danl]
My mistake is was a 2.4NA Dodge motor
September 12th, 2005
Ed Peters, retired Chrysler engineer, active racer and owner of Magnum Force Engineering, performed back to back dyno tests today on the Ishihara-Johnson standard steel combination scraper, dual-windage tray and baffle setup for the 2.4 Dodge engine (see pictures below). Magnum Force Engineering has a state of the art environmentally controlled dyno room where, among other parameters, ambient air temperature of 71 degrees Fahrenheit was held to within +/- .5 degrees. Experimental conditions in the dyno room and for the engine were normalized for both back to back pulls.
The tests were run on a normally aspirated 2.4 liter P.T. Cruiser engine with a modified engine management system allowing it to exceed the normal factory redline. The balance shafts in this engine were removed and, notably, it was equipped with the factory oil cooler for the SRT4 and P.T. Cruiser Turbo. The engine was equipped with a 195 degree F thermostat. Five quarts of fresh Mobil 1 10W-40 synthetic oil were used during each pull.
Prior to both pulls, the engine oil pan temperature (oil temperature in the reservoir) and coolant temperatures were allowed to stabilize. At each rpm increment in the tables below the temperatures were allowed to again stabilize in order to give an accurate reflection of the steady state operating conditions in the engine at that speed.
At peak rpms, use of the windage tray setup accompanied a 24 degree Fahrenheit drop in oil temperature, an 11 degree drop in coolant temperature and a 7 hp and 13 ftlb boost in power.
Ed Peters remarked that "this setup is the most significant bolt-on change for oil and windage control that he has witnessed since 1986."
In 1986, while at Chrysler, Ed performed joint research with Mobil Oil on windage losses in the 2.2 Shelby Turbo engine. He developed a performance oil pan that regained 9 hp at 6000 rpm when using Mobil 1 oil. Earlier in his career he was involved with the Dodge Daytona / Plymouth Superbird that dominated NASCAR racing for a period of time.
It is important to note that a turbocharged version of the 2.4 engine would have higher windage losses and oil heating due to the increased level of normal blow-by in the crankcase. Therefore even more benefit would be found in the use of a proper windage control system.
http://www.crank-scrapers.com/
Edited by OnyxEros (01/05/07 10:20 PM)
#879232 - 01/05/07 10:40 PM Re: Crank-scrapers anyone? [Re: OnyxEros]
RyanTSI Offline
Loc: Canadia
How does windage (I assume oil being flung all over the place by the crank) rob horsepower?
#879507 - 01/05/07 11:51 PM Re: Crank-scrapers anyone? [Re: RyanTSI]
Imagine the crank flying through a cloud of oily air. Everytime it hits a drop of oil it sticks to the crank and takes a little bit of energy to spin around/fling off. Keeping the oil off the crank keeps this from happening. It also helps protect the oil from aerating. Lots of good stuff with crank scrapers/ windage trays.
#879647 - 01/06/07 12:47 AM Re: Crank-scrapers anyone? [Re: ScottStaypuff]
RyanTSI Offline
Loc: Canadia
I never thought of oil being in the air like that. The crank cutting through the oil in the pan and knife edge cranks made sense though. Makes sense though. But like dan said, unless the car has oiling problems, power could be found elsewhere for cheaper. On boosted cars anyways. IMO
#880140 - 01/06/07 09:27 AM Re: Crank-scrapers anyone? [Re: RyanTSI]
Knife edging a 4g63 crank is always bad. Balancing is good though. If I can pick up a scraper from them I probably will. The 4g63 pans are a stamped piece of steel basically, very open. I think these crank scrapers are much more beneficial for woad wacers than drag wacers though. Drag racers probably don't even have enough time to foam up the oil. Also even 10hp worth of power really allmost isn't worth $100 investment.
#9089913 - 07/27/17 03:06 AM Re: Crank-scrapers anyone? [Re: danl]
zhengjx Offline
zhengjx20170727
burberry canada
marc jacobs sale
michael kors outlet clearance
true religion jeans sale
nike outlet online
ysl outlet online
ferragamo shoes sale
true religion outlet uk
cheap football shirts
coach outlet clearance
nfl jersey wholesale
ray ban sunglasses uk
chrome hearts outlet
louis vuitton uk
oakley sunglasses sale
louis vuitton outlet
converse shoes sale
coach factory outlet
cazal outlet
cartier watches
cheap jordans for sale
mulberry uk
burberry outlet store
pandora jewelery
adidas wings shoes
supra shoes sale
tory burch outlet online
tory burch handbags
polo outlet store
ray ban wayfarer
cheap jordans free shipping
canada goose jackets
max 90
links of london jewellery
louis vuitton borse
louis vuitton outlet stores
louis vuitton
camisetas futbol baratas
louis vuitton
jerseys wholesale
cheap replica watches
michael kors outlet store
mulberry handbags sale
nike outle
nike shoes uk
nfl jersey
kobe shoes
mizuno shoes
ralph?lauren?polo?shirts
air force 1 shoes
gucci outlet online
cheap jerseys wholesale
adidas nmd runner
pandora jewellery
swarovski jewellery
Nike Free shoes
tods outlet online
adidas uk store
true religion canada
nhl jerseys wholesale
nba jerseys wholesale
louis vuitton
thomas sabo charms
rolex orologi
ralph lauren outlet stores
louis vuitton
juicy couture tracksuit
max 1
nike air max 1
swarovski outlet
tory burch sandals
mont blanc outlet
gucci outlet online
lacoste polo
ecco outlet
louis vuitton
nike outlet store online
nike uk store
ed hardy outlet
cartier outlet
polo ralph lauren outlet
canada goose coats
sac louis vuitton pas cher
swarovski crystal
polo outlet stores
bottega veneta outlet online
ray-ban sunglasses
swarovski crystal
polo pas cher
gucci outlet online
Basketball Shoes
swarovski jewelry
gucci borse
chrome hearts online store
snapback hats
nike free running
soccer jerseys wholesale
ray-ban sunglasses
adidas nmd
burberry outlet sale
omega outlet
polo outlet
canada goose outlet store
cheap soccer jerseys
lacoste pas cher
louis vuitton
cartier watches for women
polo outlet
mulberry outlet
tory burch outlet stores
hermes outlet
rolex watches for sale
longchamp outlet online
true religion uk
nike shoes for women
hollister clothing store
foamposite shoes
louis vuitton
giuseppe zanotti shoes
nike shoes outlet
true religion jeans outlet
polo outlet
louis vuitton bags
coach handbags outlet
louis vuitton
lacoste outlet
ray bans
mulberry bags
prada sunglasses for women
tory burch outlet
birkenstock shoes
pandora bracelet
hermes birkin bag
air max 2015
air max shoes
kobe bryants shoes
louis vuitton
ralph lauren?uk
kate spade outlet online
kd shoes
gucci outlet
prada outlet online
soccer cleats
gucci outlet online
nike store uk
new balance outlet
mulberry outlet
rolex watches outlet
fitflops uk
polo outlet
cartier watches
ralph?lauren
cartier watches for sale
mac cosmetics sale
polo outlet stores
lacoste shirts
michael kors outlet stores
ray ban sunglasses wholesale
swarovski jewelry
valentino shoes
rolex outlet
michael kors factory outlet
gucci bags
salomon outlet
louis vuitton
fitflops uk
air max trainers
yeezy boost 350
gucci outlet store
ralph lauren shirts
rolex uk
fred perry polo
canada goose outlet online
birkenstock shoes
hermes outlet store
mcm backpacks
#9173934 - 10/31/17 03:23 AM Re: michael kors factory outlet [Re: ]
HYst Offline
